Relay for lights question.
Thunder
FUTUE TE ET IPSUM CABALLUM Lisburn NI
I have a couple of PIAA wiring looms, one uses a relay labeled LR-7, the other is PL5FB.
Can anyone tell me what is the difference between them and if using them with diffferent lights from the ones they were supplied with would be an issue?
All you need for lights is a 4 pin switching relay - terminals are usually numbered.
85 - Switching feed (ie main beam feed or switch)
86 - Earth
30 - Battery positive (via fuse)
87 - Power to lights
HTH
Dave
PL5FB is for lighting applications up to 85W (7 Amps) - from Google
from memory (probably iffy) the LR-7 is rated at 40 Amps - No reference on Google
