On my R90S the transmission is held onto the rear of the engine by four fasteners. Three are nut and nut/bolt type. However, the fourth is a double ended stud. The stud screws into the back of the engine, with the middle smooth shank and other threaded end sticking out. On the corner of the transmission is a hole through which you thread the sticking out part of the double ended stud. (Does that make sense?)
Anyhow, is there a speacial tool available for inserting and removing double ended studs? My main reason for asking is that removing this stud whilst the tranny was in place would have made its removal far easier (space behind the trannny is at a premium).
Is a stud extractor the proper tool?
With the stud and tranny in place, all you can see is one end of the double ended stud thread. Any tool would just have this to work on.
Many thanks for any advice
