- Joined
- Aug 13, 2012
- Messages
- 1,031
- Reaction score
- 1
Guidance appreciated from anyone who’s had a hexhead starter motor off. I have a long standing issue with intermittent starting on my 2010 GSA. I’ll go to start the bike and although I get a clicking from the start switch nothing at the starter motor. A light tap of the starter motor with my heel usually does the trick. When it first occurred my dealer had the bike in and diagnosed corrosion in the wiring loom power supply to the starter motor. This is not covered by warranty so they did some remedial touching up of the power cable and since then as long as I liberally dowse around the starter motor with WD40 after the bike gets wet it seems to keep the issue at bay. For the first time in over a year, this week after washing the bike prior to its MOT and forgetting to spray the required WD40 on afterwards, the problem has returned. I’ve got a 10 day tour of Italy coming up in May and I’d really like to do all I can to ensure that this doesn’t rear its head during the trip. To this end I want to remove the started motor and check the wiring behind it, if necessary coating anything relevant in something like Vaseline to protect it as much as possible from moisture.
My question is, how big a job is removing the starter motor? Can it be done without removing other major components? The Haynes and BMW workshop manuals would seem to suggest that it is fairly straightforward but I would appreciate any hints and tips from anyone who has done this on a hexhead.
