removing topo map from zumo 550
davidgibson999
Coleraine
I installed the morocco topo map but I installed the full thing i.e. contour lines as well. I want to wipe it and reinstall the roads only - how do I remove the existing installation from the zumo?
If you look at the Garmins internal drive using Windows Explorer you'll find a file called GMAPSUPP.
This is the extra maps you've loaded. You can delete it here or as said before just reload the maps you want and this will be overwritten using the new maps.
Make sure you got the right filename (as posted above). You would not be the first to delete the essential maps .. :blast
It's even simpler for your purpouse (must start reading questions.. :D )
Just install the maps you do want again. The [gmapsupp] file gets overwritten automagicaly! :augie
sounds like the path of least resistance and I'll be taking it!
thanks
