remus can results
Ok well here it is ... nearly
Removal of the old can and cat was a doddle, it came off as one piece after removing a few bolts and clamps.
Fitting the new Ypiece and can was even easier. The whole job took less than 1hr.
And the dyno results ... well I couldn't be arsed fitting the original can to the y piece so i just dynoed the system before and after.
Very little difference to the top end (maybe 1hp). However big diference to mid range. At about 3,500 to 4000 it made an extra 6hp. With the original spec there is a dip in the curve around this area (probably to do withh emmissions and noise testing). This makes the bike much more responsive just where you need it.
Torque is also considerably improved.
I will post the graphs later.
Noise wise ? well it certainly sounds louder, but not intrusive. But hey what do I know I also have a Jap 4 with a straight through pipe to compare it to.
Would I recommend it ?
Yes, the improved midrange power and torque make 4th gear over taking much easier, I can also power the front wheel up in 2nd now (before I could only do it it 1st !!) And the sound is great.
Will post wav file later as well.
whats next ?
Well would be rude not to try a K&N filter, and maybe a power chip.
