REMUS REVOLUTION EXHAUST
duc9160_0
Wootton Bassett,wiltshire
if anyone is interested i have just had my GS Adventures 1st MOT test, bike is fitted with Remus can with the road legal baffle fitted and the kite mark clearly on the can exterior. The tester at my local BMW dealer wanted to fail the bike on the exhaust as he said it was too noisy, anyone else had this??
is there no such thing now as a road legal can?
Did he actualy pass it in the end?
Be a clever dick and quote the following to him:
"(d) Exhausts - on motorcycles first used on or after 1 January 1985 the silencer which forms part of the exhaust system must be either:
(i) that with which the machine was first fitted; or
(ii) clearly and indelibly marked with :-
-the relevant BS marking BS AU 193/T2, BS AU 193a, 1990/T2, BS AU 193a, 1990/T3; or
-the relevant "e" marking to show compliance with EC Directive 89/235; or the relevant "e" marking to show compliance with Chapter 9 of EC Directive 97/24; or
-the name or trade mark of the manufacturer or marked with that manufacturer's part number - relating to it.
The European Community noise limits applicable to new motorcycles first used from 1 April 1991 are:
Motorcycle Category by cm3 Limits in dB(A)
Up to and including 80 77
Between 80 and 175 (incl.) 79
Above 175 82
Motorcycles approved to EU Directive 97/24/EC, Chapter 9 will be 2dB(A) less than the above figures.
(Note: the precise regulations for motorcycle exhausts are complex and it is recommended that they are studied closely to obtain accurate and complete details of the requirements).
Before buying any replacement parts for systems listed in this section, riders should check for the relevant marks, where applicable. These will include an "e" mark for EC Directives, an "E" mark for ECE Regulations and "BS" for British Standards.
(Note: amateur motorcycle builders may be exempt from some or all of the requirements)"
The relevent link is as follows and gives you all the specific EU regs. details if you can be arsed to look them up :D
http://www.dft.gov.uk/stellent/groups/dft_roads/documents/page/dft_roads_506856.hcsp
Andres
Thats only for type approval (importing and such). For the MOT, as long as it doesn't say 'not for road use' or whatever then markings play no part in the asessment - it's all down to whether the tester considers it reasonable.
FWIW, just put mine through with a Revolution Race and it passed without a batted eyelid.
LC
Outtomunch.....just as LouCan says,the law has changed considerably regarding bike exhausts in MOT tests.
The only requirements are that it isn`t marked as not for road use,it isn`t mechanically unsafe or blowing,and that in the tester`s opinion,it isn`t excessively loud .
