I'm thinking of making this mod but will be doing a lot of motorway miles. Is the noise level at healthy cruising speeds significantly louder and tiring over distance?
I've got a Remus & Y-piece, don't wear ear plugs & I find the noise levels ok.
Hedgehog said:Almost sent myself deaf on a long (5hr) trip up from Cornwall without earplugs... & I only have the Y-piece with a standard can! Took about a month for my hearing to return to normal (or for me to get used to it).
But a good pair of earplugs does the trick. No problems now. Eh?
Paragon said:Fit one of these - forget the noise - and the cost of the Y piece and Can
Cheap, (you can make money - negative cost), quick and achieves what most Bikers want, (they will be able to hear you coming and going)
Para
pint6x said:I tried earplugs last summer when I rode my GS1150 down to Italy. I know it makes sense, I've always wanted to try them on a long journey, and with Y-piece and Remus I thought it would be sensible.
The problem I had was that it blanked off the noise soooooo much I just couldn't get used to them. I did persevere over a number of days but in the end I decided to go without and suffer the consequences.
I did have an amusing conversation with a petrol-station cashier in Germany. I still had lid with plugs in and I asked him a question. His lips moved and I heard absolutely nothing.
I found myself getting dizzy/disorientated with the plugs in - and I think they caused additional fatigue. I know noise causes fatigue, so I'm at a loss to explain why I got on so badly with them. They were the disposable sort.
On a bike without plugs your damaging your hearing at only 50mph.
After only a few months I noticed a loss of hearing and slight ringing.
I started to wear plugs the hearing didn't get any better even after 5 years but the ringing has stopped and my hearing has remained the same.
For me they are a must on every ride no matter how short or long
I would urge anyone not using them to persever you will get used to them.
Don't ask me to explain why this might have happened, but I'm sure someone must have an idea
blu
