replacement wire element for heated grips?
bikenav
Member
Llanelli Wales
My 05 1200 (50,000mls) R/H grip element is busted in 2 places first place worn second place whilst cutting grip off throtle sleeve. The element is a conventional wire rapped around the sleeve in a spiral fashion of about 0.3mm diameter unlike the circuit board type seen elswhere on the forum.My question is does anyone now what spec this wire is? Is it available somewhere?
Cheers all.
Bikenav.
I fixed mine by soldering in a piece of household fuse wire. That was 5000mile ago. Fitted new Renthal grip
i used a piece of guitar string of similar thickness. wound it for a short distance (1/2 inch?) between the two broken ends of the original.
This was on an Airhead though.
Good luck
Failed to find any wire to do a complete replacement, so soldered a repair. Be good to find a source for proper wire though.
thanks for the tips
