Thanks for the help guys
Absolutely brilliant video clip Phil, couldn't have done the job without it.
The whole thing was fairly straight forward ( as these things usually are)
providing you have the right kit. This is always my biggest concern when starting a job that i've not done before and always my downfall.
There were several items I did not have which I normally find out 1/2 way through a job or most likely
several times during a job which necessitates stopping & several feckin trips to buy tools etc which just drags a simple job out.
This time I tried to work out where I was going to get stuck. First was the steering stem bolt. I had to go out in the week and buy a 32 mm socket cos nothing I had would touch it , 2nd was the appropriate grease , I went to 4 places on Sat' morning - 2 bike dealers, Halfords, and a motor factors and none of them had an appropriate waterproof grease ( 2 said we'll have some in on Monday
). In the end i bought a CV lithium grease for bearings that claims to be waterproof.
I stripped the whole front of the bike down following the Clymer, no problems , had a look at getting the bearing cups out but they just wouldn't shift. My drifts weren't long enough, my biggest screwdriver kept slipping off the cup, i found a long piece of box section metal tubing that wouldnt get any puchase on the cups either. An hour or so later I'd got nowhere with it and was pissed off.
Yet again I was let down in the middle of the job by insufficient tool/implements.
Went back watched Phils video and they used a long solid metal rod but I had nothing similar, emailed the link to my father in law to be and asked if he had anything lying around at work like that . '" Almost certainly, I'll pop into work in the morning (Sunday
) and see ".........9am he's at the front door with a suitable rod ............9.15am both of the old cups are out & lying on the garage floor
..............it's always fekkin easier when you have the right kit lying around.
However, I couldn't get the old bearing completely off the stem and once again without the suitable tools the job defeated me.
So the FILTB has taken it to work for one of the lads in the workshop to whip off for me and then tonight I can easily put the front end back together again, job
should be done
Ian
