bandit
Hi
Anyone tried fitting the adventure r suspension to the standard adventure. Ive got a 2011 adventure dakar, it has the same engine as te adventure r, so i fancy getting the longer travel suspension.
You can get the kit.
http://www.ktmtwins.com/ktm-950-990-non-abs-adventure-r-spec-suspension-kit
However it says only for use with non abs bikes.
"If you own one of the NON-ABS model 950/990 Adventures and want that R Spec Suspension then this kit is for you. It will raise your standard suspension by 55mm so you can take on even the meanest of obstacles. This kit unfortunately was built for NON-ABS Equipped Adventures. I'm sure some guru like Craig from CJ Designs will come up with a kit to remove or disable your ABS but we will have to wait and see."
Anyone ave any idea why this is ? Cant see the connection between suspension and abs.
