Right handside rattle.
Geno
Northern Ireland
After getting valves sorted this morning ,the RHS is making a constant ticking even at startup and when running. LHS is good . Any ideas ,wasnt making it before valve adjustment. Many Thanks in advance .
Press the throttle pulley ( the wheel the cable attaches to ) as the the engine idles .
Does it stop ??
if so, don't worry about it.
Now that i found out how to do the valves , i had another go this evening ,the gaps were to big .So i started over ,now she is running real fine ,normal boxer sounds. Well chuffed .The ADV file was right to keep adjusting and they would get better . Many thanks for all your help . Now to adjust the Throttle bodies , have a twinmax coming next week .
