Road Riding and ABS Pro ?
diver1
warrington
Just wondered how many people ride (normal use, road riding only) with ABS Pro activated?
Pro's, Con's and any advice would be appreciated.
Regards,
John
How can you tell if your bike has ABS pro or not?
I have a 2015 GS TE, salesman says it has ABS pro, but how would I know??
Go far too fast into a corner, mid corner pull the brakes hard! If the bike sits up and exits the corner you don't have it. A safer way would be to get the build date from the vin number and look it up from when it was avaliable.
To the OP there is no downside to having it on, I don't think you can switch it off without switching the whole abs system off anyway.
Go far too fast into a corner, mid corner pull the brakes hard! If the bike lays down and doesn't exit the corner you don't have it. A safer way would be to get the build date from the vin number and look it up from when it was avaliable.
Fixed it again!
I think that on the XR if you engage stupid dynamic pro mode it disengages the ABS pro
I could be wrong as i have not RTFM
Why would you want to turn it off ?
Pro - I could save your life
Con- Non
I think this is the ABS pro sensor module under the pillion seat.
Who else has one of these under the seat and who doesn't?
On the road I'm not sure why you would consider removing a safety device that may come in useful at some point.
I have found myself trailing the braking deeper into corners without the bike feeling like its wanting to stand up and making the bike feel more comfortable through the turn, though not sure I am carrying any additional speed it just feel more controlled for the exit.
My 2015 GS TE doesn't have ABS Pro so I do not believe the salesman.
