Rotating switch and lever assemblies - help!
Lord Snooty
Redditch, Worcs
I've adjusted my handlebars by swivelling them forward and now I need to rotate the switch and lever assemblies backwards. I've loosened the obvious screws but nothing doing...anybody know how to do this? Is there something blindingly obvious that I'm missing.
Appreciate some help here lads and lasses.
Mike
Mike, if it's the same as the GS 11 undo the Two philips screws one on each switch assembly and then lift the front of the switch gear off you will then see Two Alan screws, slacken these and 'way to go' you're there dude. :D:D
Rotating Switchgear
Lord Snooty
If it makes you feel any better, I had this same question a few weeks back, having also rotated the bars. I spent 10 minutes looking for the "EXTRA" bloody screws/bolts to undo.
Paul's right, there are couple of alan bolts under the plastic housing aroud the swith gear...remove the screws holding on the housing and voila! You can now see the bolts you've been looking for....simple, but not that obvious.
Simon T:beerjug:
