ROX RISERS
bob the grizz
South West
HAS ANYONE FITTED THE 2 " ROX RISERS ??
WOULD I NEED TO GET LONGER CLUTCH n BRAKE LINES AS ORIGINALS LOOK QUITE TIGHT :eek:
I've got Rox Riser on mine with the stock bars, the lines were tight but workable if you played with the position of the risers and bars . Note I'd previously removed the location pins on the switchgear so I could get the lever angles where I wanted and not where yam dictated , which will be needed to get the brake lines loose enough for full lock. In the end though, to get a wider range of bar position options I fitted lower Pro Tapers and the Roxs though in hindsight I think the Pro Taper ATV mid bend bars may be a cleaner solution. Ithink there is some posts on yamahasupertenere.com and possibly advrider regarding these .
