First 600 miles - keep below 4,000 rpm and no fast acceleration, keep it gentle. Don't lug the engine - keep the revs under load above 2500 preferrably 3000 and higher. Vary the throttle opening and avoid runs with steady speed.
Once you have had the 600 mile service where the engine is re-torqued, valve adjustments are made and other components are checked you can start to have some fun. Don't forget to book this service when you collect the bike if the lead time for servicing is more than a week - 600 miles will go REAL fast, if a little boringly, and if you overshoot the 600 miles dont start to thrash the bike until you've had it checked.
Between 600 and 1200 - increase the max rpm gradually and start to apply more load under acceleration. so that towards the 1200 mark you are running the engine regularly up to 6500 and opening that throttle wide and hard.
After 1200 miles, give the bike it's dinner and ride it hard regularly. This will seat the piston rings and reduce oil consumption. This is vital to minimise carbon buildup, a result of lugging the engine and riding like a pussy.
These engines don't respond well to being ridden gently. Search for this subject on
www.advrider.com/forums and you'll find that this is the general concensus. Also search for 'pinging' and 'carbon' if you're interested in why.
Good luck with the new bike.
