I've been doing something similar to my girlfriend's Fazer today ... using it as a guinea pig before I do the GS
On the subject of LEDs and resistors: rather than wiring each LED with its own resistor and connecting the whol lot in parallel, a simpler way to do it is to wire 4 LEDs in series, and then a single resistor also in series.
If the LEDs require 3.2V each, 4 x 3.2 = 12.8. Assuming the supply voltage is 14.8 (to make the numbers simple
) then the resistor needs to drop 2 volts off the supply. With a 20 mA current, this equates to a 100 ohm resistor. (R = V / I = 2 / 0.02 = 100).
I found this a convenient arrangement: 4 LEDs and one resistor in each indicator.
Hope this info is useful.
