Windmill John
Totally baffled now.
Bike was idling up to 3k
Stripped carb, looks good
Fitted new throttle cables, tappets done.
Here comes the strange bit.
After a run, the lowest I can get idle is 1500 to 1700 RPM
Throttle stops now don't even touch the cam and there is slack in throttle cables.
Choke cable adjusted.
Okay, it gets more weird.
Stick vaccumn gauges on.
Right hand carb doesn't do much, shows below 10 PSI even when I crack the throttle.
Left hand carb changes gauge with throttle; good.
Hang on , there's more.
Close the right hand mixture screw totally and revs drop; good.
Close the left hand mixture totally, nothing happens at all!!! It makes no difference.
What am I missing
John
What am I missing
John
