S.O.S
mavis cruet
somewhere, over the rainbow...
help!!!
just put the bike (R100gs) back together after fitting new crank and gearbox oilseals. turned it over gently with kick (no ignition, plugs, carbs etc) and after a few turns its stopped. havnt tried forcing it, yet. does this sound like the old thrust washers been dislodged inside whilst the flywheel was off? i found out that it mooves AFTER id taken the flywheel appart! if so, am i right in thinking you can pull the head and barrel off and wiggle the washer back into place? will the washer need replacing? hmmm.
