SC-Project 'zorst
WindyChuffer
Londinium
FUCK ME ITS LOUD! Just the job for scaring jaywalkers in London. Great on overrun. Awesome in tunnels. Cant wait to rock up to the underground car park at work tomorrow.
Quite easy to fit tonight. Was not amused initially you had to bend the supplied straight mounting band around the can but easy to do.
Could do with a lip to stop the baffle dropping down the tube when you undo the retaining screw. Had to remove the can to get baffle out as dropped to the bottom.
Other than that, given its less than half the price of an Akro, so far so good.
Also took my pillion footpeg hangers off whilst I was at it.
Yeah it's a beast...sounds like a FULL ON race motor under bridges\tunnels\etc...but it purrs like a kitten when cruising.
You might need to leave the muffler bolts a little loose to allow for some expansion pivoting action...had a issue with mine getting louder during a ride until i did this.
Precisely which bolts do you mean? What issue did you have? Ta.
The two bolts on the muffler bracket...just snug tighten them.
If yours isn't getting louder as it heats up then you are OK...so just enjoy :D
Confused. If those bolts are loose then its going to swing around and eventually loose a nut. Cant see how tightness of these makes any difference to the exhaust noise.
Looks good, and a bit more subtle than the Akra.:thumb
