Scorpion Exhausts...
MrC
Kinver, West Midlands
Hey!
Does anybody know or has anyone tried to fit a Scorpion end can to an 09 model GSA? Their website states 2004-2006 models only. Is there a difference between these year designations and an 09 model? :(
If one of the knowledge Guru's could help, that would be great!
Cheers :thumb2
If it helps, I've had the same Titanium Remus Revolution end can on all three of my GSes, an '04, an '07 and an '09.
Hey!
Cheers :thumb2
Should be the same fitment:thumb
I have a Scorpion slimline end can on my 1200Adv, and have a feeling that there is a bit of a loss in low-down power/torque.
On a trip down the Route de Grand Alpes - a pal on a similar bike (standard can) was in 3rd going up hairpins, where I was in 2nd to pull cleanly out of the bend. Cornering speeds were the same.
At higher revs - it could well be breathing better, and of course - the can is smaller and lighter.
Just something to consider.
Al :thumb2
Al :thumb2
The end can won't affect the engine "breathing" as the engine opens up after the CAT is removed. A non standard end can will only give you a louder noise.
Having said that, my opinion is that the 1200 needs some back pressure so if you had the baffles out, you may of lost a bit of oomph!
Err - that looks a bit of a contradicton :nenau .............. what effect can the baffles have - if you maintain that the end can as a whole - makes no difference??? :rolleyes::rolleyes::rolleyes:
A non-standard can may have an influence on the gas flow from the engine - no matter what the cat is responsible for.
Al :)
Al :)
Al
Yeah, I didn't put it very well to be honest. I've tried every combination on my 1200 and the best is Keihan headers (others are available:augie) and standard can.
It was OK with a Scorpion end can with baffles but felt a bit breathless without. We made a Keihan end can and had the same result i.e good with baffle, a bit breathless without. Without the baffles it's also way to noisy.
With standard headers on i.e with the cat still on an aftermarket end can gives more noise but I haven't noticed any difference in power with baffles in. With baffles out, plenty noisy but I thought there was a definate loss of bottom end power.
Basically, you will only get a decent increase in power by removing the CAT and either keeping the standard can or having a baffled aftermarket can so you have some back pressure. You may get a little more by standard headers and a different end can but it wouldn't be much.
Don't ask me how it all works but those are my findings!
I found when I changed to the BMW Akrapovic can, the bike seemed to run smoother, without being too loud, and the burble and poping on the overrun is easier to do too :augie
The big advantage of an aftermarket can, as far as I can see, is the loss of weight.
