screen zoom
manxmann
newry, northern ireland
my 660 has started to do strange things. when you turn it on and it displays the map, it zooms out to show most of the country. when you set off and get a bit of speed up it zooms in and shows the road you are driving on and as you slow back down it zooms out again to show most of the country again. If when you start it up and use the + or - button it will then work properly till the next time it powers down and restarts. its only just started doing this so is the unit or software at fault. any help on how to fix this would be great
been on to garmin. had to rebbot the unit back to factory setting by turning the unit off then pressing the bottom right hand screen and turning unit back on at same time. lost all data but it has cured the problem:clap:clap:clap
