Sensor gap?
Beemer Bob
London
R1150GS
April 2002 build
7000 miles on the clock
Hello all,
I thought I’d be brave tonight (with my mechanical skills, changing a light bulb is hard work :o ) and remove my rear brake caliper to check the state of pad wear. Everything went well; the pads have still got some life left on them. I managed to reverse the procedure without a hitch.
What I wanted to ask, do I have to check the ABS sensor gap? If so, where is it located? (I have the BMW calipers and not the brembo ones)
All help is much appreciated.
Beemer Bob
Beemer Bob.
I assume that your 1150 is pretty much the same as my 1100. Here's a pic for you to compare.
You only need check the ABS gap if the wheel [or the sensor I suppose]has been removed. The sensor is not part of the caliper, the sensor is just above the ABS gap sticker
Caliper to rear wheel drive torque is 40Nm
Russ.
