Just got this from the Twin cam workshop CD
(+) Reading fault memory with BMW Motorrad diagnostic system
(-) Reading fault memory with BMW Motorrad diagnostic system
=> Oil change, engine, with filter (Description in item: 11 00 611, Billed as a separate item) Annually or every 10,000 km
=> Oil change, rear wheel drive (Description in item: 33 00 501, Billed as a separate item) every two years or every 20,000 km
=> Checking valve clearance (for maintenance) (Description in item: 11 34 502, Billed as a separate item) every 10,000 km
=> Gearbox-oil change (maintenance) (Description in item: 23 00 510, Billed as a separate item) initially after one year, then every two years or every 40,000 km
=> Replace all spark plugs (as part of maintenance) (Description in item: 12 12 509, Billed as a separate item) every 20,000 km
=> Replace air filter cartridge (for maintenance) (Description in item: 13 72 505, Billed as a separate item) For off-roading or every 20,000 km
=> Checking or replacing air filter element (for maintenance) (Description in item: 13 72 508, Billed as a separate item) For off-roading
=> Repleace belt for generator (as part of maintenance) (Description in item: 12 31 657, Billed as a separate item) every six years or every 40,000 km
(+) Visual inspection of hydraulic clutch system
(-) Visual inspection of hydraulic clutch system
Load more how to do stuff on it hope its of some use to someone on here
