FatBob
I noticed recently that the pads on my rear brake are worn unevenly - this might have happened a while ago before the last MOT when I was told that the rear brake was binding a bit. It should have been fixed then but maybe the problem has come back.
I took the caliper off, put some grease on the sliders, everthing seemed to be moving OK as far as I could tell - never tried fiddling with the brakes before so I don't really know what to expect. Pistons didn't seem to be stuck as I managed to push them back in with my fingers.
I put everything back together and went for a test ride. I didn't use the brake much but when I got back the rear disc was quite hot and the front barely warm. On the centre stand the rear wheel spins OK but not as easily as the front so I guess the brakes are binding a little. The question is, is this normal or do I need to get a garage to look at it? Seems like the design of the brakes is more likely to cause this on the back than the front.
I am preparing for the onslaught for asking such a dumb question...
