simple add on for non TFT bikes
malcopopolo
Surrounded, Staffordshire
Been around on car forums for some time ..
They do suffer one inherant fault, that if carried over to bikes you need to be aware of.
Once you fit an Elm / OBDII to the OBDII port, any error's you may encounter that generate a fault code & check engine light are not indicated or
stored, as the connection of the ELM unit stops the fault codes being flagged.
