BOLT. Banjo bolt.
I was fitting an oil cooler and the banjo bolt that comes with has a check valve ball bearing in, well I pinched it up and it went snap!
Does anyone know where I might get a replacement ? The parts are from the states, I'm not sure if it specifically made or they are common part, it's a metric standard size, but with a floating bbearing. I presume it's a one way valve.
