So how noisy should a PC be?
  • Thread starter Thread starter guitarman
guitarman
New PC finally delivered and installed but it seems quite noisy. The fan works constantly and is not actually very quiet. It wil be sited under a desk but is sitting next to it "in the open" at the moment so perhaps it just seems noisy.
I should say that the old PC is nowhere near as noisy.
Any comments?
Dick
Dick
I had exactly the same on my new pc when it arrived a few weeks ago.
Got the engineer out & he changed the fan - problem solved!
He told me that a lot of his calls were about fan noise & that it was just luck of the draw as to whether you got a noisy one or not.
PS My new pc's fan runs constantly too - but the man said it was meant to - something to do with the latest processors generating lots of heat???
My new Dell is very quiet. All Dells are deliberately made with large lazy fans that generate low noise.
I was fixing a mates Evesham Micro PC last night and the fan in that nearly drowned out the radio it was so loud!!
Chris
Yup, my Dell can not be heard.
My locally built performance PC with super quiet fans and gold PSU sounds like a generator and sucks up half the carpet. Needs a good blow job with the airline every couple of months.
Looks like it's a support call then :(
Pity as everything else is working fine.
Dick
Also depends what chips inside.. The faster the chip the hotter it gets the more cooling it needs
Pentium runs cooler so needs less cooling
I bought a quieter PSU
And a quite fan for mine... it's still to loud for my liken'
It's Intel Pentium 4 3.4 - fan's still noisy though....
Dick
If you look in somewhere like Ebuyer.com you will see a wide range of fan prices and as with everything you pay your money and get what you paid for. I have a Compaq that is silent but I bought a cheap PSU for a friend as a replacement and it was unbearable. If its a new PC call em back.
AndyT
a P4 is a chip that generates a fair ammount of heat. not as much as an athlon maybe, but still needs a lot of effectve cooling.
i think pc cooling is something of a black art & am always trying to shut my pair of noisy athlons up :)
try fitting something like this to the case fans, then adjust the speed while checking the motherboard utility for CPU/system temps.
perhaps something like this on the CPU if you want to go quieter.
original manufacturer may have cut corners on such things to save money.
Apparently this is a common complaint with new PCs. Acceptable levels of noise are of course subjective but new PCs, so I'm told, now run a CPU fan, a power supply fan, a case fan, a chipset fan on the motherboard and often a graphics card fan and I'd bet that fans are something that corners can be cut on.
I have to say I was always a bit bemused by magazines that ran articles on making your PC quieter as I wasn't even aware of the fan(s) on my old PCs. Now I understand :(
Dick
