curiousexplorer
on entering a roundabout, in 2nd gear, leaning into the corner, and a bit of throttle to have the bike pull around the corner.
Suddenly the engine just conked out, rear wheel locked up, and made a half circle of rubber on the street, and I was down. It happened in one second, no time to pull clutch lever at all.
No personal damage, and there was no other traffic, lucky!!! just a bent hand protector.
Picked up the bike, pushed it to side of the road, tried to start it, started immediately, as if nothing had happened.
Now, this puzzled me no end. I could not point to any cause of what happened here.
Rode home, about 40 kms, fingers on clutch lever (!) no problem.
Decided I did not want to wait till this happened again, could not be so lucky then!
Remembered all stories about stalling engines, a while ago. Main causes: loose battery cables, side stand switch, fuel controller failure.
Last year I bought a 2nd hand controller -the black one, mine was still aluminium color- and stashed it away behind the buddyseat.
So I now decided to take preventive measures, shorting the side stand switch, replacing the fuel controller, checked battery connections and condition of battery.
I made a test ride, and to my surprise the bike was pulling harder, and smoother. the new controller made a difference. It came from an F700 but I suspect it has the same innards as my old one.
My wife has the same f650gs as me, (both have over 30k on the clock, no problems so far! ) and I managed to find another controller, and replaced her old one too. Again, resulting in more pull.
Now, is there anyone with more suggestions/ measures to prevent a future stall ??
Much appreciated,
Hans
Much appreciated,
Hans
