http://www.ngksparkplugs.com/techinfo/spark_plugs/installation.asp?nav=31300&country=US#installing
and exactly the same figures here:
http://www.championsparkplugs.com/search_char.asp?seenWarning=1&manufacturerID=
Plug torque settings
It is essential to tighten a spark plug to the specified turning angle or torque setting. This is for a number of reasons, over tightening can cause;
1) Damage to the threads in the cylinder head (especially aluminum heads).
2) Damage the threads of the spark plug.
3) Damage the internal seal of a spark plug allowing combustion chamber blow-by.
Under tightening of the spark plug can cause plug overheating and possibly pre-ignition. This is because one of the primary purposes of the spark plug is to remove heat from the combustion chamber, it does so by transferring that heat to the engine head. If the plug is not properly tighten it will not have sufficient contact with the head to transfer that heat. Proper tightening procedure is described below.
Screw in the spark plug finger tight until the gasket meets the cylinder head. Then seat the plug/gasket with a torque or turning angle wrench as specified in the chart below.
Spark plug type -Thread Diameter- Cast Iron Cylinder Head (lb-ft.)- Aluminum Cylinder Head (lb-ft.)
Flat seat type -(with gasket) -18 ø mm- 25.3~32.5- 25.3~32.5
-14 ø mm -18.0~25.3 -18.0~21.6
- 12 ø mm- 10.8~18.0- 10.8~14.5
- 10 ø mm 7.2~10.8- 7.2~8.7
-8 ø mm -- 5.8~7.2
Conical seat type (without gasket)- 18 ø mm -14.5~21.6- 14.5~21.6
Conical seat type (without gasket)- 14 ø mm- 10.8~18.0 -7.2~14.5
definitive answer.
Torque is independent of size of wrench or bolt head size.
Torque is calculated at the AXIS (c/l) of the thread.
Settings are specified as clean and lightly oiled threads - NOT dry.
Phil
