Speakers / Bluetooth fro Arai Chaser? Any recommendations?
  • Thread starter Thread starter Reggie P
Reggie P
Quick question ..I'm just about "up to speed" with mounting my new Zumo 590LM on my F800GS ...
I had envisaged buying a new Shuberth / Senna combination , but until I do that later in the Summer ...may i kindly ask - is there a recommended Bluetooth solution for my Arai Chaser ? There isn't much room around the ears for speakers and on-line research is proving slow .
Do you guys have any recommendations? I'm not sure whether I just want "turn audio" from the GPS or music / iPhone call audio.
As a temporary solution whilst you wait to buy your new lid and Bluetooth set-up maybe one of the cheaper headsets of eBay would suffice until then. The helmet speakers tend to be quite thin. I had to add padding behind my Autocom speakers in my Aria Quantum as well as, conversely, cut away a little of the soft foam on the cheek-pad. The speakers on mine are under the cheek-pad lining.
For best performance having the speaker plumb central to your ear canal and lightly touching your outer ear. The difference careful and considered set-up makes to the usability is considerable, especially once you're travelling at over 40-50mph
