Speedo on Quest 1
Invicta Moto
Hythe, Kent & Islington N1
I am sure I saw this tip before on here but have trawled through loads of posts... and not found it.
How do you get the Quest to display a speedo in the righthand panel instead of the route info?
I'd RTFM if I had one. On Garmin's site the Quest has disappeared from the drop downs and only Quest 2 is choosable....
you reset the display to show it.....there's an option somewhere for choosing the things it displays.....
fekk, that's not very helpful is it:blast
I'll go get mine out of the LC and have a look :)
MENU>EDIT FIELDS then highlight which one you want to change to speed, press OK and select the speed from the drop down list.:thumb2
If you don't have any fields shown at all (Ie just a full screen map), you first have to enable them by going to 'Map setup' and turning Data fields 'on'.
HTH
