I've got my 1150GSA stripped to change the clutch (due to oil contamination).
I'm now ready to split the gearbox from the engine and it's started to come apart, but is stuck in one area
The problem is at the lower right hand side, seemingly caused by corrosion at the locating dowel
(confirmed when removing the gearbox to engine bolts, the only bolt with any rust on it was at that location).
I've soaked it with penetrating oil and tried a few wacks with a wooden block and hammer but it's not budged at all.
Just for info, rear wheel and swingarm still attached with trolley jack under gearbox.
Any advice please?
.The problem is at the lower right hand side, seemingly caused by corrosion at the locating dowel
Any advice please?
