SPOTLAMP FITTING
timtim
Driffield, Yorkshire.
I am planning to fit a set of upper and lower crash bars to my 2010 1200GS.
They are the S W Motech ones.
At the moment i have a pair of BMW spots fitted, using the std plastic brackets, but i will have to remove these if i fit the upper bars.
Any suggestions anyone please.
The GSA bars have brackets already welded to the upper bars, but i need to see hoe the lights will fit with the Motech ones.
Any help much appreciated.:confused:
post some pics of your current setup and the new bars without lights so that we can see what you're talking about
you will regret the upper bars.... they are poorly designed.
the U bolts take ages to install/remove and they touch the oil line to the cooler
:thumb2 On the last if you want to take the side panels off the top bars are a pain in the arse so get all your wiring done and run first. :flag
Hmmm... Story of my life !
Looks like they'll be up on the old fleabay if anyone is interested :mad:
Thanks for your input fellas.
Fitted heavy duty plastic cable cleats top and bottom, two minute job to remove/refit,also waterproof sockets on the wiring.:thumb2
