is this a common problem on acceleration my screen vibrates and makes a loud rattling noise. its all tight but still seems to vibrate but only on acceleration any help or comments welcome
Get a louder exhaust or ear plugs. Mine sqeaks a little if I really listen for it, (mind ewe I have a segam screen fitted that was the reason for me listening in the first place) But when ewe have two fecking big pistons going ten to the dozen what do you expect.
Check all the spacers and guides are in the correct order as when I changed my screen I dropped the left one and put it back together in the the wrong order
Worth a look i reckon, don't ask me the right way around mind, as it was two years ago.
Allan
my screen used to vibrate, know how you feel it used to annoy the hell out of me. traced the problem to the pivot points in the centre area of the screen where it attatches to the metal bar mount. there was a small amount of play side to side. removed the sreen and slid on 2 small o rings to the pivot points to act as spacers, worked well had no problems since.
hope this helps
cheers boys tightened up to torx screws and no noise or vibration than again i also took the baffle out of my remus so i can't hear anything!!!!!!!!!!! seriously sorted will get afew rubber rings to help.thanks
