Stainless Fasteners for £60
Hi, looking for opinions on this stainless kit for a GS1200, can anyone recommend these - or another source?
http://cgi.ebay.co.uk/BMW-R1200GS-STAINLESS-STEEL-FASTENER-KIT-R1200-GS-ADV-/23043080
Views please?
Ta very much
Not sure what happened to that listing! But, I see that both Chris Shaw & Steptoe show disc mounting bolts as being replaced with stainless - my belief was that these need to be high tensile bolts & stainless aren't suitable - is that not true?
Not sure myself but have had Stainless disc bolts on several bikes, couple of K and 2 R RTs (Chris Shaw kits) last was an 1150GSA (Steptoe Kit) must have done well over 100000 miles with them fitted without any problems. Hardest part is getting the old ones out without wrecking ether the bolt head or the hub, bit of localised heat is the answer, small blow torch or hot air gun.:thumb
Sure if you do a search there will be an answer on here, always found help when needed..
:rob:rob:rob:rob
I also fitted a Shaw stainless steel set to my 1150 about 50k miles ago. No problem with the brake disc bolts.
Mike
