Hi guys, i new on here and i'm after some help
I own a F650gs twin and recently decided to do a small service on my bike before going on a trip to Fort william.
Oil and filter changed. Air filter replaced and while i'm under the covers new plugs fitted.
Everything back together and i let the engine tick over while i put my tools away. Ready for work the following morning, or so i thought!
On my way to stopping at traffic lights the bike just cut out. Throttle rolled off front brake applied clutch in etc etc, all text book stuff. Engine had been revving around 3k before i started to slow down. Mmmhh i thought, never mind these things happen. But its happened most days since and its now getting to be a real PITA!
I've taken the bike to bits again to check everything is as it should be, but nothing is amiss.
I've even tried resetting the throttle by rolling it on and off slowly 3 times with the ignition on, but to no avail.
Clutching at straws now, but i ordered a service kit from the internet and i'm not sure if the plugs could be different, old ones in the bin, before you ask
Could it just be wrong plugs? I've never had this problem with any otherof my Beemers so i'm a little baffled.
Any help would be much apprciated, my thanks in advance
William
William
