From http://www.motorbike-search-engine.co.uk/2006_Bikes/f650gs_dakar.php
The F650 GS Dakar special employs extended 210mm (front and rear) suspension travel - which is 40mm longer than on the standard F650 GS. The seat height of the Dakar model is 870mm (instead of 780mm) ......
the 19" GS front wheel also fits - i didnt get on very well with the 21" front wheel on the road, although plenty of people do so i guess its just me!
I felt when I had the Dakar model that the front wheel semed to like following road banding, markings etc, even if it was not where you were pointing.
Dakar has a high mudguard as standard, but TT do a lower one.
Be aware that not all 650 GS's and Dakars are the same as some have dual spark plugs (newer ones) and others don't (older ones). AFAIK the dual spark are supposedly better on fuel consumption and not as revy in nature.
Not found that myself, so could be a tyre issue. I use conti escapes for road trips and they are good enough to scrape the panniers on the deck
As for twin/single spark, I have regularly got 70mpg out of a single spark engine when tooling around on twisty roads. If the twon spark is better than this then good o, but I'm happy with 70mpg![]()
I had tourances, and the front felt like it had a mind of its own. Fitted a 19" wheel and the problem went away, again on a tourance, although it went for a service at the same time and the steering head bearings needed tightening slightly so maybe that was affecting it too. I hadnt even test rode it before i bought it, my previous was a funduro and i just knew i wanted one! Maybe a standard GS would have been a better choice as i have yet to ride it off road, its my only bike and i dont want to trash it learning.
Will probably try Conti Escapes next though.
As for fuel economy, on my 200 mile A road/ Motorway commute last friday i got 76mpg, although i never really thrashed it due to the weather.
Its a fantastic bike though, cant think of anything that could replace it!
I dont need to get anywhere fast these days, Ive done my time wearing out the titanium bolts on my sliders, its time to hang up the racing leathers plus the jacket is too tight now, havent you got a Dakar? Fancy selling it on? Or if you know anyone, I think I might have found a buyer for the blade so will be loking in earnest.
