gopher
Evening all.
I posted here a couple of months ago looking for help with starting problems. Many thanks to all who suggested fixes....
The original post is here -
http://www.ukgser.com/forums/showthread.php?t=105828
The problem is it's back.
The bike - F650GS, '00, 35,000 miles, serviced around 4000 miles ago
The symptoms - Either hard starting (Starts but dies off quickly) or the idle speed runs at between around 1900 and 2500 revs, getting faster and then slower. This doesn't always happen and sometimes fixes itself once the engine is warm and can usually be solved by turning the ignition off and on again. The problem first reared its head about three months ago, pretty much since it's last service.
What I've done to try and fix it -
-Checked battery connections aren't loose
-Reset the 'Brain' several times using the three methods I've come across (Taking out the correct fuse, Disconnecting the battery and removing the brain unit, each for at least fifteen minutes)
-Doing a throttle position reset
-Cleaning throttle body, checking for cracks in the rubber
-Cleaning out the Idle air bypass (if that's it's correct name), which was filthy
-Checking throttle cable routing and correct positioning
-Checked air sensor is positioned correctly and plugged in
-Replaced spark plug with extended tip iridium variety as suggested on the chain gang site
-General look around for broken/bare wires
My question is this - Is there anything else I can try myself before bringing it in to a dealer and getting the faults read?
Many thanks for reading and sorry for the unusually long post.
