Ok everybody here are MY findings (I'm 6'5" and wear a system 4 evo - which I like by the way!)
I've been experimenting with the Adventure screen - I drilled another set of mounting holes so that it's top sat about 60mm higher and the whole screen sat more upright. This was not a deal better so this afternoon I took the jigsaw to the bottom of a pattern standard screen I'd got hold of. I taped the whole of the bottom of the screen with masking tape and then marked a 30mm line following the contour of the light curve etc.
The jigsaw blade was new so of I went - about half way across the screen cracked upwards so I carried on and it cracked again.
Having drilled the Adventure screen without any problems it was obvious that the perspex BMW use is softer and tougher (something they've got right?)
To hell with it I'll give the standard GS screen a go I thought (how reckless!) - same procedure and 30mm line as above and the jigsaw went through it like butter.
I tidied up the edge with a file and wet & dry and fitted it in the midway position.
Out on the road at 60 -70 mph it is definately the best yet!!!
If you put your left hand (don't use the right one - you'll slow down!!!!!!) on top of the screen you feel smooth are pressure and then drop it down behind the screen you can feel the turbulance.
Having stopped and altered to the low setting I tried again and found that the air right up to the front of my visor and just above it is still (just move your hand around, you'll feel the different air turbulance / pressures)
None of this is scientific but Tobers set ME on the same train of thought as Geoffrey with his comments about turbulance being created by the air behind the screen 'popping'
At the moment it seems to have worked for me as well
Sorry if you got bored reading this but i've tried to cover all aspects.
Sherpa
