any ideas?
R100GS paralever.
front brake light switch is stuck ON.
the cause is not obvious (i'm good at obvious ).
symptoms -
the lever sits in approx 1/4" nearer the 'bar than it should.
so - the light switch thinks the brake is applied.
...as if the master cylinder pushrod confused: wotever its called that forces fluid along the line) that the lever pushes against is not returning to rest (fully out) - hence the brake light stays on.
nothing appears seized (in the cold and dark this evening) and IF the brake is binding - its very little.
i'll get a better look at it tomorrow / but hoped that someone among the collective would go...
"ahhh! - i know what that is!"
i wait in hope.
Cheers all.
TIA
R100GS paralever.
symptoms -
i wait in hope.
Cheers all.
TIA
