Bigtwin
Aurelius said:I recommended this model only because the pre-VTEC VFR's dating back to 1986 were notorious for charging system failures - QUOTE]
Really - first I've ever heard of that - American version thing? Mine never missed a beat.
Bigtwin said:Aurelius said:I recommended this model only because the pre-VTEC VFR's dating back to 1986 were notorious for charging system failures - QUOTE]
Charging system failures are the single most talked about problem on VFR owners forums:
http://www.yft.org/tex_vfr/tech/rr-maintenance.htm
Honda has consistently denied knowledge of the problem, but that claim in belied by constant changes to the rec/reg design - sometimes in the same model year. There's a company in Europe (Electrex) which sells aftermarket charging system components for a wide variety of motorcycles. According to their database, the number of reported charging system failures on Honda VFR's exceeds that of any other motorcycle.![]()
Aurelius said:The KLR650 is a fine bike for the money, but it has several drawbacks: an uncomfortable seat, terrible brakes, lots of wind buffeting at highway speeds, and tubed tires. Get a flat tire on one, and you'll have quite a job fixing it - assuming you have all the tools, know how to use them, and brought along a spare inner tube. With modern tubeless tires, you can fix a flat with a simple plug kit and be back on the road in minutes.
North said:Without question the right bike is the Honda Ruckus.
Good on gas and cheap to buy.![]()
