Swing arm oil level
solidstate100
Hi Peeps,
As title above - I am aware of the amount of oil required in the arm, (0.15L I believe, and how to check it (vertical dip showing 2mm on your dipping device of choice above the shaft through the filler bung) but somehow I seem to have ended up with the level at the bottom of the filler bung (distracted whilst filling I believe:eek).
Anyway, its easy to sort out by draining it, but is anyone aware of any negative effects if I just leave it? Dosent seem to be leaking etc, was just wondering really:nenau
Thanks for the replies, but thats not what I was asking!! its blindingly obvious how to reduce the level, the question was, are there any negative effects of leaving it overfilled??:nenau
