System Case Fitment
  • Thread starter Thread starter Matt
Matt
Are all System panniers case's the same? ie can a set from a K1200 or RT be fitted to a GS Adventure assuming the rails are in place.
Cheers,
Matt
Thanks Johnny, thought I had found a good deal on Ebay but they are off a K.
There are 2 sets on there that will fit your GS if you look under BMW in accessories.
HTH's
System Cases....
BMW System cases for a K1200RS WILL fit a GS as it too has an upswept exhaust. The case carcass is identical......
Re: System Cases....
Originally I thought that they would, but dealers tell me that the lugs for a K12 are slightly different and mounted in a different position,than the R or GS system case backs.
Who is correct.........???
Re: Re: System Cases....
My pal has both 'bikes......GS & KRS, uses the same cases on both......
Now I'll have to ask him how he does it........:confused:
Re: Re: Re: System Cases....
Stand corrected if so and blame the dealer.........go bid
