TEchlusion Help Required
needlongerlegs
Felixstowe, Suffolk, UK
Gezzas,
I ordered myself a Techlution fron TTS (£180) last week it turned up yeasterday but I'm a bit confused.
Its called a TFI BOX 1030 is this the old type have I got the rong ern?
should it not say R239 or something
Help?
Not strictly true that you have the old one... you have the first one. There is now a second option in the R259.
The R259 costs more (about £250 ?) and is a simple install which simply plugs into extisting bits in the fuel injection system whereas the FI 1030 needs to be spliced in.
The R259 also retains the lambda sensor... I'm not sure but I think you may have to remove it on the FI 1030
HTH
Adam
R259
Send it back!
R259 costs £189 from TTS!
New model is so much easier to install ( no cutting up your loom ) and has several improvements over the old model. Check the Techlusion website for the details.
Cheers, Rick.
