Techlusion r259, voltage settings?
fatnfast
SE Kent, England
Can anyone give me a good starting point for the techlusion r259 voltage settings? This is for a 2002 Single Spark 1150 with Remus (baffle out), y-piece, standard filter and yellow ccp. I have done a search, but there are a few different recommendations. I understand a dyno set up will sort it, but if I can put in good basic settings this will save on dyno time (and money!),
Thanks.
The basic setting as set up on a multi meter are Green 0.6v Yellow1.3v Red1.7v and the Cruise pot 3.6v that with the idle at 1500rpm thtas from the techlusion manual and works for me, the pots are very sensitive so just tweak a little at a time.
Pete A
Thanks Pete, I take it your bike has the same mods as mine? I will give them settings a try.
