Techy thingy miyjig!!
  • Thread starter Thread starter newman7096
newman7096
Had Techlusion fitted with Remus Y Piece and Remus titanium end can. Im happy with the peformance but smells really rich.... Anyone got any good settings... using 1 oclock, 2 oclock etc...:rolleyes:
Smelly tips
Get the engine upto normal temp, go for a fastish run; go some where that you just pull up without upsetting traffic--you will need tools for a plug remove refit road side job--- put them in a bum bag its safer than a pocket.
Heres what to do (on your safe bit of road) hit approx. 5000rpm and hold it (any gear say 3rd for arguments sake) for about a minute if you can. Now the tricky bit, simultaneously hit the engine kill switch and pull in the clutch, DO NOT LET THE CLUTCH IN UNTIL YOU STOP.
ARE YOU SOMEWHERE SAFE-- away from traffic, bike safely on its stand.
Remove one plug (the easy one for you) look at the colour of the colour of the spark plug tip and electrode. If the colour is biscuit brown or golden then the mixture is not too rich or lean, if black and sooty then its too rich, grey going on white its seriously lean.
What you have just done is known as a plug chop, it is no where near as accurate as getting the whole set-up correctly adjusted by a knowledgeable bod on a dyno.
Your comment about smellng rich could well be the new exhaust burning off some of its initial corrosion inhibitor (oil) don't forget the freer flowing can is passing more fumes-if you wil and is bound to smell different to your old restrictive big bang quietner.
At the end of the day you may be able to arrive at a fairly good set-up by trial and error, you don't say if you've fitted a freer flowing air filter.
Have fun.
I got some advice from fellow GS ers on the tech site , If you have got a 1150 then try settings 3 , 4 ,4 ,8 which is a little more richer than the std settings if you have got the R259 system, it worked for me, found the std settings still to lean for my taste.
Hi,
Just bought one so excuse my ignorance but I guess that is:
Green 3
Red 4
Yellow 4
Cruise 8
(Got K&N, Y piece and laser exhaust)
Cheers:cool:
Bike has been dyno'd
My 1150 GS is fitted with Remus Y Piece, Road legal Remus can and Techlusion fuel injection box with standard air filter.
Wollaston's of Northampton fitted the box but I decided to let TTS set it up correctly.
The results;
1st run without adjust ment peak power 81.3bhp
2nd run after minor adjustments peak power 82.4bhp
Torque is up too!
Not huge increases but certainly noticable!!!
__________________
"keep your knees in the breeze"
