Windmill John
Hi All,
Is this possible?
3-400 miles ago, my bike started started starting on 1 pot; the 2nd would kick in virtually straight after.
Since then, it is lacking massive power. If your travelling at say 40 MPH and you whack open the throttle, nothing happens. There is a slight almost indiscernable increase in speed. Eventually it will build up, but your now lucky to get 80MPH
The most important fault is that if you are cruising along, it feels as if someone has momentarily killed ignition; like a type of hunting.
I've just ordered some plugs, as mine have done 10k, tappets are good; okay valve clearances for the pedantics
A similar thing happened a year ago, and a local dealer put it down to a Hall sensor; I was £300 lighter afterwards!
I've seen other links to replacing it yourself with a part from an electronics supplier. I'll be honest, I'm a little shy of fitting this part.
If my R80 goes wrong, I know exactly where to look, but my GS is confusing me. It had new injectors last year, fuel filter replaced about 10k ago, covered 72K miles.
Could someone please point me in the right direction.
If Steptoe was closer and it wasn't one of my work transports, I'd drop it off there. But, I do like to try and resolve things.
Cheers Guys.
Is this possible?
Cheers Guys.
