First off, thanks to all of the guys that stopped on the hard shoulder of the M3 to see if I was ok last night. They were:
1) A guy riding an 1100S - sorry forgot your name but I still have your email address.
2) A biker guy driving home.
3) A guy on an old Guzzi (I think)
4) And a guy on an R1150GS with a UKGSER.COM sticker on his beak.
Here's what happened:
Moving to lane 3 to overtake I bumped over a cats eye and then all drive was lost. First I thought it has just popped out of 6th gear. Alas no. There was no drive in any gear and a nasty screaming/grinding noise that reduced as I went slower. Pulling the clutch in didn't make the noise go away either.
I can spin the rear wheel in neutral and it feels just fine. I can put it in gear and can still spin the rear wheel but there is a rapid grinding noise whether the clutch is in or out. The noise is if the final drive shaft wasn't quite attached to the drive shaft and you can hear the splines rubbing against each other as one bit spins but the other bit doesn't. If that makes sense.
The GS has never shown any signs of impending failure before. No slipping out of gear, no untoward noises of any kind.
I know the clutch needs replacing as when it's hot in very slow traffic it can slip a bit when pulling away quickly. But if this problem was the clutch I'd still have drive right?
I've not had a chance to do any other investigation other than that but at first guess I'd say the gearbox to drive shaft splines have broken in some way.
So, the GS is off the road now and the RT is still off the road with it's final drive at the dealers getting fettled.
If I get time tonight I'm going to remove the GS's final drive and if it looks OK fit it onto the RT. Hopefully that can get me back on the road.
Mind you, it'll be sods law that when I remove the GS's final drive loads of bits fall out.
Anyway, thanks again to the guys who stopped to offer help - should they be reading this.
Regards
Rob C
Regards
Rob C
