Thermometer
  • Thread starter Thread starter schnauzer
schnauzer
Can anyone recommend a small digital type thermometer? I had one on the VFR800, missed it when i moved onto the Mille, and somehow expected the GS to have one :mad: centigrade preferred!
It's Maplin's product code: GW57M.
I have one under the dash on my 1150 with the external sensor glued under the front of the beak (I've also shortened the sensor wire but cutting, soldering and shrink-wrapping).
As others have said, they stop working when you wash the bike (but I've never had a problem when riding in the heaviest rain), but they do come back when they have dried out a bit.
At under £8, it's a handy item.
Greg
That would be this then, the rain hasn't bothered it ......yet
here's what Chris Gledhill made me:
Its always been 100% waterproof
How much?, and how do we contact him please.
Gary.
whatton63, how'd you mount that under the console? I have a Halford's clock/thermometer, but no bracket. Also, does the yoke foul the thermometer at all on full lock?
I have mine in the same position using the velcro patches that come with the Maplins unit.
whatton63 appears to be using some plastic-coated pipe clips.
Greg
Its mounted using two of these spring clips (black plastic coated though) attached using the shortest self tappers I could find. And no, it's not in the way of the steering lock. I was getting odd temp readings due to heat rising from the engine, so I've moved the sensor under the beak.
