Sorted Carcraft £5
long lead on sensor so can be mounted on forks near Abs sensor to give near as pos road temp and a built in sensor for normal air temp.
At least 2degree difference from road to air
Sorted Carcraft £5
Personally I would learn the craft well before relying on instrumentation. Be careful of shaded & treed areas which are more prone to freezing ( & staying frozen) even when the temperature gradient shows greater than 2 deg... A close eye on the "change" of the road surface has kept me safe up to now. A quick check on the local weather conditions prior to the ride will alert you to problems. All obvious stuff really....
PS. Don't waste your money on thermometers of any kind, you'll find yourself on your backside before you know it...
